- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
In the camera i can't switch to manual modus with the wide and 2x cam. Anyone else experienced this?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
From the manual:
Hint
You can also switch between cameras by swiping down the camera screen.
To use the zoom
•Pinch in or out on the camera screen.
•Use the volume key.
•Tap (Switch angle button) repeatedly to select x1 (normal) or x2 (2x opticalzoom).
•Drag (Switch angle button) to the left and right.
Note
•Zooming is only available for the main camera.
•Switching angles using (Switch angle button) is not available when the manual mode is selected
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
From the manual:
Hint
To use the zoom
Note
