Hi, usually I use Microsoft Launcher in my phones, but with the Xperia 1 I can't use the multi window functionality with this launcher, why?
It only works with the default launcher.
I've an Xperia XZ and one XA1 and both can do multi window with any launcher.
Hi @DJCorreia, let me see if I can help out here.
Do you receive any kind of error message when you try to use split screen on your Xperia 1? The way to use split screen has changed a bit since the XZ and the XA1-series. In order to view two apps at the same time in split screen on your Xperia 1, please follow the steps below.
Do note though that not all apps support the split screen view. Let me know if that helped!
Hi Martin.
Thank you very much for you help, it works now
What I've tryed before was start the split screen functionality from the sensor menu, and when I was tryed, it was pop up a mesage telling that multi window doesn't work with microsoft launcher.
But doing it like you said it works perfectly.
No worries, @DJCorreia! I am just glad to hear that you managed to make it work again!
Feel free to return if you have any further questions! Otherwise, have a great day!
