Hi there,
Can I use the Xperia 1 charger and cable when charging the Sony WH-1000XM3 headphones? Will it damage them or is it safe to use it?
Thank you very much
Hi @NeluGeolgau19,
Just as @uliwooly mentioned, it should be totally fine.
You may want to double check with the Electronics support though just to be 100% safe since they are the ones providing support for the headphones. The charger that is included with the Xperia 1 is a power delivery charger and that is a fairly new technology, but I'm not sure if that makes any difference.
You can reach our Electronics support if you click the link below > scroll down to the bottom of the page and you will find a country selector > choose the country you are in > scroll down to the bottom of the new page and you will find "Contact Us" on the right hand side.
https://www.sony.com/electronics/support
I hope that helps and feel free to let us know what kind of answer you get!
Dear Jonas,
Thank you very much for your help regarding this.
