Smart Case!
KenHoc
Smart Case!
Does the Xperia 10 vi have a Hall Sensor to support a Smart Case?
My old Sony Xperia XZ2 came with a smart case. I can't seem to find out if my new Xperia 10 vi supports this function.
I am hoping it does as I found that function saved a lot of battery.
Thanks for any help.
Tags (2)
2 REPLIES 2
SatoruGojo
Hi @KenHoc , seems like it doesn't support the hall sensor, you can check the compatible accessories here.
sam.kim168960
The Xperia 10 VI does not have a Hall Sensor, so it does not support a smart case like the one you had for your Xperia XZ2. Unfortunately, this means you won't be able to use a smart case to save battery on your new device.
Hope this helps!
