MODEL DSC-W510
I cant put the date in frtont of the pictures,nothing doesn't say in the manual instruction.
if you know anything ,please help?
Hi telashe10, welcome to the Sony Forums
Perhaps the function you're looking for is 'Date Stamp', where the image has the date 'printed' onto it?
LIke many modern digital cameras, the W510 does not have a date-stamp function. What you see on the built-in screen is only for review and display purposes.
However, assuming you're using Sony PMB to download your photos, you should be able to add a date stamp once the image is on your PC. See the following tutorial for details:
http://support.d-imaging.sony.co.jp/www/disoft/int/pmb/feature/edit/attach_date.html
PMB for the W510 can be downloaded here:http://www.sony.co.uk/support/en/product/DSC-W510/downloads/PMB
Hope that helps
Mick
Hope that helps
Mick
