2015 Bravia Android TV Issues
NickCo1979
6,373 REPLIES 6,373
Heckie
Much happier!
I'm not too fussed for YouView but 5.1 from ALL apps (that support it), especially Google Play Movies and Kodi is a must.
Spotify/Google Cast support would also be nice.
nickbaker66
Mine didn't auto update
Still running 🏃 5.01 I've checked for an update nothing available I wonder if they have pulled it
dspencer999
OK - so it all seems a bit nippier I guess, but not masses.
Freeview Guide still takes about 5 seconds to change channel.
Everytime you hit TV Guide, it come up immediately, then goes off, then on again?! LOL
Have I missed the HDR settings?!
Also, how do you switch on Netflix 5.1?
Haven't tried Plex yet, other than seeing if you can select 3D from within the App, and you still can't.
Netflix seems to now have an Auto Start on, which is a bit annoying when you're just trying to read up on a film and it starts! Can you turn this off?!
To be honest, I can see very little difference other than a Freeview icon at the top of the Guide, and the menus are slightly quicker.
This is on an 8509C incidentally. Perhaps I'm just feeling negative tonight?!
UnoBorg
@dspencer999 just press yr home button then go into settings at the bottom & change audio
UnoBorg
@sassbs thx for getting back appriciate it
dspencer999
@UnoBorg - Clearly it's late and I'm being thick here. Still can't see how to switch on 5.1 for Netflix?!!!
I hit [Home] and [Sound] - Where then?! Do I have to have Netflix running?
Heckie
For 5.1 Netflix you need to set one of the settings under sound to Auto 1, and also in the app itself make sure its set to 5.1.
UnoBorg
As @Heckie said from home button then drop down to settings then sound & SELECT Auto 1 ....worked here
I didn't have to change anything in Netflix It done It auto
theshamelessmanc
Just having a further play this morning with the TV, and I'm not sure if this helps, as I have Netflix 5.1 now, but the Netflix app shows in the play store on the telly. It is also showing that it needs updating as of the 13th October. Maybe that could help
Tbh.. I think the latest update just made everything worse?! The menu I
sluggish and even slower than before and the TV won't connect to my network
(cabled) unless I force a reboot every time I turn it on
