1) Hot Swap HDMI doesn't work - manifested by no input on HDMI channels 2, 3 and 4 on the KD-49X8305C. Workaround - reset the TV, either by holding down the remote power button for 5 seconds or by switching the TV off at the wall and then back on again. Further details on this thread: https://community.sony.co.uk/t5/televisions/kd-49x8305c-hdmi-2-3-4-inputs-not-working/td-p/1944435
3) Netflix App doesn't work - this seems like the app has been deliberately disabled. So far a support case has only recommended that a factory reset be performed (took two days to get to that cracking piece of advice.....), with no improvement as a result. A temporary (albeit for advanced users only) workaround is provided by MikeLothian on this thread - https://community.sony.co.uk/t5/televisions/netflix-support-for-kd55x8509c-android-tv/td-p/1945360
I got PAP to work by selecting a HDMI Input and then press "Action" (x8505C).
Looks like it works, with possibility to change size for the windows.
I was hoping PAP also would give me PAT, but unfortuantely not. Think text support sucks on this TV.
Hi
I have an issue with my KDL-43W805C. If i use the Sony Video App to watch videos on my Seagate NAS drive, i can watch 1 file and then it shows all the folders as being empty. I have to navigate my way all the way back out to the list of devices where it shows the seagate as asleep, tap to wake. It wakes without having to tap and i can than go and navigate files again. And so the cycle starts again. I have installed VLC and this works fine so no issue with the NAS. A small bug i know in the grand scheme of things, but one that def needs to be squashed.
Regards
@petersincock wrote:Hi
Regards
KODI is worth downloading for playing videos from a NAS. I have my WD Mycloud set up using the SMB option and it scrapes all artwork and information from the internet. It makes navigation etc so much easier.
https://support.unblock-us.com/customer/portal/articles/291560?_ga=1.93575125.951366307.1455801018
Instructions
| Primary: | 208.122.23.23 |
| Secondary: | 208.122.23.22 |
Changing DNS like that won't work in Android 5.1.1
Follow this guide, it will work with your Android TV the same. Also, I'm pretty sure the DNS server numbers you have listed are blacklisted by Netflix now.
Guide :
http://www.androidbeat.com/2015/05/how-to-change-dns-server-android-phone-tablet/
wrote:Changing DNS like that won't work in Android 5.1.1
Guide :
Thanks for the guide. I managed to get through to change the DNS settings however I just kept getting a message saying that my addreess was invalid. I used the same settings that are automatically used when first adding the network.
