43XE8077 suggestion for program guide and timers
TBill01
I notice that when I set a timer within the program guide for TV channels, then a "red bar" appears along the timeline, but there is no indication in the actual program entry itself. No dot in the program box.
This is a real pain... if you want to come back later and set another program, then you are unsure which program is causing the "red bar" - so you then have to go to the timer list to find out (and go back again etc).
Why not put a red dot in the program box entries? Then just by bringing up the guide, you could see which programs have already been set for record?
1 REPLY 1
EdwinaU
Moderator
Hi TBill01,
Thanks for your suggestions for this program guide and timer, we welcome your feedback.
Best wishes,
EdwinaU
