Just updated to Nougat on a 43X8305C over the air and the Home button has stopped doing what it used to do. Now it brings up Programme Guide and YouView buttons both of which can be reached by other routes. No longer listed are the Apps and Inputs that were previously listed and can now only be reached by a series of much more complicated button presses. Could be I'm missing something but to change the functionality of one of the remote buttons does seem a bit drastic. Please advise what I'm doing wrong or what the fix is. Thanks!
Sony KD-55XD9305. After Nougat update USB-recording stopped working if I use timer-option. The cause of this failure is "The mainpower was scwithed off when recording was starting". If I start recording when TV is on, recording is continuing to its end correctly. I use remote to start and shut the tv like I ever done before. With Android 6 USB-recording worked well.
Markku
