AV 2 input grayed out (KD 49XD8077)
profile.country.IT.title
Luigi_R
From the home page under "Inputs" ( Ingressi in the italian version) the AV 2 port is grayed out and if I click on it nothing happens. The same if you click on the DIGITAL/ANALOG button on the remote control, the item AV 2 is skipped.
5 REPLIES 5
EdwinaU
Moderator
Hi Luigi,
Thanks for reaching out to us. There's some useful information on this help page that may help you with your AV 2 question. Let us know how you get on.
Cheers,
EdwinaU
Luigi_R
Thanks for replying but it does not tell me why the second av receiver does not work. If the port is there why can't I use it?
Owen_G
Hi Luigi,
Could you please let us know what it is that you've connected to AV2?
Thanks,
Owen
Luigi_R
I just found the solution here: https://community.sony.com/t5/Television-Apps-Widgets/I-can-t-get-AV-input-2-to-accept-a-signal-AV-i....
Actually nothing was connected as for the other inputs, but only AV2 was greyed out
Tansea
Hi, that page is now unavailable. I have the same problem with an 8305. Can you give a description of the solution assuming there is one.
Tansea
