KD-55XE9305
Boycecheese
KD-55XE9305
Anyone else having problems with BBC iplayer using the screen settings that have been applied to HDMI inputs? Other streaming applications use the “App” picture settings. Usually flips the screen settings to HDMI 2 for some reason, rather annoying. Do you people think this is a sony or iplayer problem? I was hoping it would be fixed when the Dolby vision update was applied, but nope!
1 REPLY 1
LightFoot
Specialist
Hi @Boycecheese
The BBC iPlayer simply uses the last input used. For example if you watch Digital TV and then go to BBC iPlayer you will find it is using the Digital TV picture settings.It makes no difference on my KD-55XE9305 as I use the default standard settings for everything which I find are the best for me. It doesn't really matter as the eyes get used to any setting. I can understand why you notice if you have different settings for each input.
