- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
KD-65XF8596 Internet speed connection
Hello there,
i have an year old Android TV and i noticed that i have some kind of internet speed limitation on my TV.
every time i try to run a speedtest on tv using wifi the speed is limited to aprox 25Mbit while on same network my laptop or phones are running much more faster.
the TV has 802.11a/b/g/n/ac wifi which should support much higher speed now i am not sure where could be the problem. can anybody with the same model do the speed test please?
i tested the connection with 3 different providers ! same results everything runs fast except the TV...
i see the same problem with ethernet connection
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
How do you measure the network speed? Are you using 2.5 or 5ghz connection? The ethernet connection support a maximum bandwidth of 100 mbps and my own KD55A1 tops it up when streaming from a DLNA server (measured by a known bitstream test file that is the only valid speed test)
