Netflix support for KD55X8509C Android TV
LucioGodoy
Hi All;
Is Netflix available for the KD55X8509C TV pls?
I cannot believe that Sony has released a TV which includes the Netflix button on their remote control but no support for Netflix?
Many thanks
Lucio
57 REPLIES 57
MikeLothian
I'm not advising installing a different version, only the version that's in /system/apps
marpinch7
Ah I see. I thought it was weird that the netflix logo was in there if it wasn't meant to be found
marpinch7
Surely they didn't hide it because there was no 5.1 support? Because that's the only issue I've found so far
jumpsuit
Well I don't think your TV will sudenly teleport into another dimension, but the official line from
Sony is that they do not advise and to reassure members that they are investigating. :slight_smile:
MikeLothian
Has anyone gotten anything more than sterio PCM passed through the TV? I've got my PS3 connected up via HDMI3 and the sound is outputted via ARC on HDMI4 but I only get sterio out - I've currently got it set on Auto 1 which should pass any compressed audio straight through
marpinch7
I'm still only getting stereo through TV speakers nothing through Sony home cinema when using Netflix although sky works fine through home cinema
marpinch7
Just tried to use Netflix and it has stopped working and I get a message saying it is not compatible with this device
marpinch7
Working again this morning, issue at Netflix end according to support pages
marpinch7
Turned tv on this afternoon and it rebooted which I presume was due to an update. Now getting netflix in 5.1
NickCo1979
Hi All, had an email from support this afternoon about the Netflix issue, apparently new firmware is due on the 15th June to fix the problem. Email snippet below:
<Email Snippet>
Thank you for your recent e-mail.
In regards to your query, the higher technical team advised that a new software update will be released in 10 days that will rectify the Netflix issue.
Thank you for your enquiry.
Nick
