"Sony Select an error has occurred”
Risc0n
Contributor
I did a factory reset of my TV today. Now Sony select will not load, which means I am missing BBC iPlayer and Amazon Prime.
I tried manually starting but it comes up with the above error. Was all working fine until reset, tried multiple factory reset and still same error.
What is causing the problem, I have the firmware that came out last week
Sony XE90
12 REPLIES 12
Risc0n
Contributor
Yes indeed, it is working again now. Seems like Sony needed to update the server configuration for the latest firmware update.
bluehorseshoe85
I am still having problems.
Now the sony select apps have reappeared, however at least some do not work.
I cannot open bbc iPlayer and ITV (possibly others). When I try and do so, they each say ‘loading’ and then eventually ‘an error has occurred. Please try again later’.
Any ideas?
pb1965
Have you tried doing a soft reset of your tv? Don't know whetherthis nwill work but nothing to lose.
With the tv switched on, direct the remote at it and press the power button for 5 sec or so until a powering off message appears. Then wait about 20 secs for tv to re-start itself.
