Is there a way to remove the “Live” tab that appears when you use a TV tuner? It hides the Continue Watching feature which is far more useful to me, and seems to slow navigation significantly.
The only solutions I’ve found are to downgrade the Google TV Home app, or delete the tuned channels, neither of which are ideal.
50X90S, latest firmware, Android 10.
Hey pabulous, is that on the YouView apps, if yes, which one can you add a picture? Or digital channels?
Hey, sorry for the late response. This is what I'm referring to:
Right now it's showing both, but the majority of the time the "Continue watching" section disappears. As I stream much more than I use YouView, this is unfortunate. I believe they are related because this started happening when the "Live" tab at the top first appeared.
The only workaround I've found is to remove the tuner channels but this is obviously not ideal either, as I do use it occasionally.
