Setting Location on ITV Hub
EmilyOMeara
Every time I put my postcode in to set my location for ITV hub it refuses to save it. Any suggestions on how to fix this?
Tags (1)
13 REPLIES 13
Alastair1972
Could you try the following below:
Press Home on your remote
Scroll down to 'Settings'
In the TV section scroll right to 'Apps'
Go to 'System Apps'
Hold the right button and scroll to end to 'YVServiceHostAPK'
Select 'Clear Cache' and press 'OK'
Then select 'Clear Data' and press 'OK'
Alastair1972
Go to 'System Apps'
It worked for mine, hope it helps
Alastair1972
Go to 'System Apps'
rob2691
Thank you @Alastair1972  that YVServiceHost clearing cache and data has just worked for me. This had frustrated me for weeks so finally came looking for a fix and it’s done the job. Cheers 👍🏻
