Sony 55X9005CBU - Stuttery Video
wutang200
Youtube video has a stutter or jerk every few seconds of playback no matter what the quality is that I'm playing the video back at. Tested from 720p all the way to 4k but same problem!
Also streaming video from the dedicated Plex app is the same!
Any way of fixing this issue??
wutang200
Just to update on this, it's now fixed possibly with an update as playback is much smoother and nicer even 4k stuff.
6 REPLIES 6
Anonymous
Not applicable
Hi there
Hard to know how to help without more detailed information, but you are not the first to report this.  See the following post by EggDublin: here
So how to help you?  Can you confirm if you are using wifi or a lan cable to connect the tv to your router?
wutang200
I'm using a LAN ethernet connection going into a gigabit router with a 50MB Virgin fibre line. I've tested using WiFi and LAN and both the same. Ruled out low bandwidth causing this by trying to playback at 720p and lower but same problem.
The stutter or judder is every 30 seconds or so and easily noticeable.
Anonymous
Not applicable
With the upcoming FW update, hopefully this may resolve itself.
wutang200
Any ETA on when this FW update might be coming?
Have Sony set a date for the FW update yet??
wutang200
Anonymous
Not applicable
Excellent - thanks for posting an update!
