XH92 + PS5
raver010
XH92 + PS5
Ive recently bought an XH92 55inch tv. I have a PS5 pre ordered. Both TV and console can run 4K at 120hz. Im asking how i go about doing that and getting the most out of both products when the time comes? I just purchased a high speed HDMI cable that can run 4K at 60hz, but do i need an ultra high speed cable that can run 8K at 60hz to get 4K at 120hz? Or will i need a different HDMI 2.1 cable all together when the 2.1 software update is released?
1 REPLY 1
Hi raver,
Usually the PlayStation will adjust the picture setting the the best available option. However, I think you can also manually define the output signal. And yes, you will need a cable that supports 4k@120Hz.
