Youtube stopped working KD-49XE7005
Hogar1973
YouTube was working fine for the past 1 month. Then stopped working suddenly.
The other apps working fine. I checked my Internet connection, works fine.
I also switched off everything unplugged and replugged the wires, and still unable to get in YouTube app on TV.
By the way, YouTube works fine on the other laptops and phones.
6 REPLIES 6
IamNic
Hi ,
go tour your app library and set YOuTube back to the default settings as well as deleting the apps storage and the cache.
That should fix the problem.
- Nic
profile.country.LV.title
Vizediktator
@IamNicwrote:
Hi Hogar1973,
- Nic
How do I do that? Which buttons do I have to press? When I am in the app library and YouTube is selected (but not clicked on) and I press the OPTIONS button on the remote nothing happens... Is there a special combo?
IamNic
Hi @Vizediktator,
you need to go into your TV settings and navigate to the "App" sub.menu.
There you can go to the "running apps" and select YouTube from there.
Then you should have the options I described (Clear Data|Clear Cache).
- Nic
Vizediktator
Unfortunately I cannot find the App sub menu in the TV settings. When I press and the HOME button first and then open Settings (the lowest possible option on the screen), I get two other options: system settings and customer support. If I choose system settings I can then navigate to Picture, Sound, ... and so on. But there is no app sub menu...
IamNic
Hi @Vizediktator,
I own a 3 year old Android-TV, therefore it could be, that my menu-structure differs from the one on your TV.
Maybe there is a guide online on how to find the correct menu on your particular TV.
- Nic
Vizediktator
Ok thanks for your help. My TV is the KD-49XE7005 as mentioned in the title. It runs on Linux, as far as I know.
