My flashlight icon disappeared
samaa
٢٠١٦٠٣٢٩_٢٢٥٤٠٨.jpgHI
My flashlight icon disappears and appears by it self from the active quick settings bar although I did added it and never removed the list٢٠١٦٠٣٢٩_٢٢٥٣٥٧.jpg
36 REPLIES 36
Ceddoux5
It may be caused by a third party app. Which apps are installed on the devices having this issue?
McVitas
That's interesting. Really - seems like in my case I no longer have a problem since I stopped using TSF launcher and replaced it with Action Launcher... but sorry I can't be certain if the light toggle isn't there just now and tomorrow it won't disappear again :-]
Susang
My light is dispersed from my quick setting when I try to add from the system UI not working..
BeatriceK
Have the same issue on my phone and yes it's there I'm safe mode as well. So annoying. Doesn't have any other flashlight apps installed (except one that uses the screen).
32.2.A.5.11 on Z3.
BozackDK
I have this problem as well, and have had it for a month or so - not sure if it was after an update. The flashlight icon comes back after a reboot, but always dissappear again after a little while, very frustrating.
My phone is a Sony Xperia Z5 Compact.
Please, Sony, are you going to fix this?
RLV
When you slide down where the flash light short cut use to be - there is a pen icon (edit) - click on it. Then you can choose which short cuts to drag into the slide down menu.
SakeSama
The Simple Advice, GOD I feel aso stupid, Spent hours going through every nook and cranny to find the TOURCH tab control, andv DUH there is NOT ONE, and all I had to do was REBOOT my Cell and there is was !  THANK YOU A MILLION TIMES!
