Xperia C3 Battery Issue
Проблема с акамулятором Xperia C3
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
What seems to be the issue?
Hi @Mavr, sorry to hear about this.
The behaviour that you are experiencing, is it that the device turns off even though you have battery left and you can't power on the device, or is just that the battery runs out very quickly?
If you haven't tried to restart your device in safe mode, I would recommend doing that, so we can see if any of your downloaded applications are the cause of this.
Let us know how it went!
Xperia C3 Battery issue
Hi @Milad2, welcome to our forum!
I can't see any text in the post you made, could you please get back to me with some more information? That way I will have an easier time assisting you in the best possible way!
Thank you.
The device needs I c power and it doesn't valuable because the model of the device became old fationed what about that?
Hi @Hodhod!
I'm not quite sure that I understand your question, would it be possible for you to elaborate a bit?
Thank you!
