How to change the battery?
Sonitor17
Hello, I have the E5 only since yesterday. Now I'm interested in whether or how to change the battery.
GT
4 REPLIES 4
Jonas
Master
Hi @moonhopper, congratulations on your new Xperia E5! Slightly_smiling_Face
The battery in the Xperia E5 is embedded and non-removable so if you need to change the battery you will need to get in touch with your Local support team and they will arrange a repair for you.
I hope that answers your question! Slightly_smiling_Face
Coligny
Batterie non remplaçable : pas écologique et cher !
Non-replaceable battery: not ecological and expensive!
GT
Tags (1)
Jonas
Master
Hi @Coligny, welcome to our forum!
Your question has been translated to English as this is an International forum.
I understand your concern and I will make sure to forward your thoughts on having a battery that you can replace on your own internally as user feedback! Slightly_smiling_Face
Have a great weekend!
Erickgta
 Yo tengo un Xperia E5 también. Tienes que buscar un cuchillo o una navaja e introducirla en los bordes de la tapa y después abrirla la batería es de forma rectangular con color amarillo en los bordes hay hay unas cosas triangulares color negro y tienes que quitarselas luego sacas la bateria y colocas la nueva.
I have an Xperia E5 too. You have to find a knife or a knife and put it on the edges of the lid and then open the battery is rectangular with yellow on the edges there are some black triangular things and you have to remove them then take the battery and put the new .
GT
