- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
October 2019
October 2019
Storage
My Sony Xperia x5 has a small amount of storage left. I have installed a sd card and it still shows limited storage. How do you transfer data to new sd card
1 REPLY 1
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
October 2019
October 2019
Hi @Tomjones1, welcome to our forum!
You can transfer data to the SD card if you follow the instructions below.
- Find and tap Settings > Storage & memory > Transfer data.
- Mark the file types that you want to transfer to the memory card.
- Tap Transfer.
If applications do not show up in the list of available content that can be transferred to the SD card, you will need to do it manually.
- Find and tap Settings > Apps.
- Tap an app that you want to move to the memory card. Note! Only some apps can be moved to a memory card.
- Tap Storage.
- If the app supports changing where it's stored, a CHANGE button appears. Tap CHANGE.
- Tap SD Card > MOVE.
Let me know if that helps!
