Dear all I have problem while Im charging my xperia L1 its really take to much time for almost 1 hours it's charging only 6% it's happening since 5 days before please help me to solve my problem thanks alot
Hello @Zayn1987, sorry to hear that!
According to our environmental declaration the standard charging time from empty to full is 3h and 48 minutes. This was tested when the phone was turned off and charged with the original charger, so it might take longer while the phone is in use and if you use a third party charger. Are you using the original cable and charger? if you are charging your device using a USB port, try using a wall socket as the device will charger faster that way.
I recommend that you temporary put your phone in safe mode and charge it as you have started to experience this behaviour very recently. Charging in safe mode is a great way to make sure that no third party application is running in the background and using more power than the phone is getting from charging. Your phone will also charge a lot faster if you don't use it while charging.
Keep me updated, I would love to know how your phone is doing!
I used Google Translate to find the meaning of your message. Kindly post your future questions/feedbacks in English so we can assist you, this is an English based forum.
