How to print contacts or create a file to view them?
@griz1 depending the Android version on your handset, open Contacts, click on the 3-vertical-dots top-right menu, tap then "Import/export": Tap now on Export to SD.
It will generate a vcf file you should be able to open with a lof of avaialble applications for both Windows and Mac computers.
Thank you. I'll give that a try.
