In my xperia L while i click the wifi button it says "turning on" for a while and gets turned off.. Similarly with bluetooth.
Then i updated my phone for 4.2.2 and it started working for a little while. Again the same problem occured.
Please help me ?
I have exactly the same issue with my Xperia L also. Updated to Android 4.2.2 aswell. Same situation...worked for a day then back to the same issue. Anyone know of a way to fix this as i'm DESTROYING my contract's data allowance at home with lack of Wifi.
@Jaydestarr wrote:I have exactly the same issue with my Xperia L also. Updated to Android 4.2.2 aswell. Same situation...worked for a day then back to the same issue. Anyone know of a way to fix this as i'm DESTROYING my contract's data allowance at home with lack of Wifi.
Settings-Backup & reset- Factory data reset.
If still you are facing the problem then
Repair your phone
Bridge (for Mac)
Factory Reset Didnot work
My Xperia L is not even allowing me to repair*
@KartheekPalepu wrote:Factory Reset Didnot work
Can you please write in detail that what is the error you getting while trying to repair?
working after factory reset thanks alot
When i try to turn my wifi on either it switches off my mobile / it gets blocked saying "TURNING ON" .
It gets restarted nearly 10times and then it gets connected to my WIFI.
The same with the Bluetooth.
same problem here.......after updating to 4.2 ......the phone restarts from the first second ....i'v downgraded to 4.1.2 version 15.0.A.2.17 .......and i dont have the restart problem, but facing now another problem.......wifi and bluetooth stuck on opening .......can someone help here ?
my wifi doesnt have a problem to connect but when connect to a wifi it is connected but could not receive any internet data when surfing the internet
hope to reply as soon as possible
help me fix the problem
:smileyplain:hi just i want result of this problem.i'm asked to the sony show room they said me that it was an software problem .i want the reason for this problem....:(
