Hola que tal
quisiera saber por que mi dispositivo Xperia no soporta la memoria SD de 32GB ya que probe con dos distintas y en otros dispositivos FUNCIONAN mas sin en cambio en el xperia no funcionan cabe destacar que el lector funciona perfectamente ya que tengo una sd de 4 Gb y la lee correctamente ¿ a que se debe este problema? y ¿como solucionarlo ?
Hello, how are you?
I would like to know why my Xperia device does not support the 32GB SD memory since I tested with two different ones and in other devices they work more without changing in the Xperia they do not work it is worth noting that the reader works perfectly since I have a 4Gb sd and Read it correctly. Why is this problem? and how to solve it?
GT
