sony L1 hot battery
Hello! buy my sony online to clear argentina and they did not advise me correctly since this model has a built-in battery. It is the first time I buy Sony and the truth is that the battery lasts little and gets very hot. Is it normal or is there a problem with this device? Thank you
sony L1 batería caliente
hola! compre mi sony online a claro argentina y no me asesoraron correctamente ya q este modelo tiene batería incorporada. Es la primera vez q compro Sony y la verdad es qla batería dura poco y se calienta mucho. Es normal o hay algún problema con este aparato? gracias
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
There's nothing wrong with your phone, the more you use it the hotter the phone it'll get
