I recently bought an Xperia L. I updated it's software after 3 days and the next morning I found out that whenever I start it. It stays in the SONY LOGO as soon as you start it. It's batteries die and it happens all over again after charging
UPDATE !!!!!!!!!!!!!!!
WHEN YOUR SONY XPERIA L(C2105) FREEZES AT THE "SONY" LOGO AFTER UPDATE.
JUST REMOVE THE BATTERY AND UPDATE THE SOFTWARE AGAIN AFTER THE UPDATE TRY BOOTING IT UP AGAIN.
IF PROBLEM PERSISTS. CHARGE YOUR PHONE, AFTER CHARGING FOR A BIT AROUND AFTER 15 MINUTES. HOLD THE VOLUME KEYS UP & DOWN TOGETHER WITH THE POWER BUTTON SIMULTANEOUSLY UNTIL IT VIBRATES OR POWERS UP. REMOVE YOUR FINGERS FROM POWERING THE PHONE AS SOON AS YOU FEEL IT VIBRATE. THAT SHOULD REMOVE THE FREEZE. PLEASE REFER TO THIS VIDEO http://www.youtube.com/watch?v=DU2u0ISzTzs
THANK YOU !!!!!! HAVE A GREAT DAY
I suggest that you try to run a software reinstall using SUS.
http://www.sonymobile.com/gb/tools/update-service/
If the problem still remains you should contact your local support team, to have the phone examined and fixed at an repair center.
http://www.sonymobile.com/global-en/support/contact-us/contact-info/
@keplunk wrote:I recently bought an Xperia L. I updated it's software after 3 days and the next morning I found out that whenever I start it. It stays in the SONY LOGO as soon as you start it. It's batteries die and it happens all over again after charging
Hi keplunk
I suggest you please repair your phone with SUS OR PCC
Bridge (for Mac)
How do I repair it? I used Update Service to update it then it happened
Should I Factory Reset it???
atjauninat ja telefons ir blokets ar telefona pinkodu ka vinu var atjauninat
At the same time, the phone is not locked and the phone is locked
GT
