Two questions about L1
Vanina79
Bonjour je souhaiterai savior comment mettre mon clavier en mode azerty et aussi  comment enlever le mode inconnu quand je passe des appel sur xperia L1. Merci a ceux qui repondront.
Hello I would like to know how to put my keyboard in azerty mode and also how to remove the unknown mode when I make calls on xperia L1. Thank you to those who answer.
GT
1 REPLY 1
Aeternvm
Hello,
To change to AZERTY, using swiftkey:
In SwiftKey you can choose to set your keyboard layout as QWERTY, QWERTZ, QZERTY, or AZERTY. To change your layout, please follow the steps below:
  1. Open the SwiftKey app from the list of apps on the device
  2. Tap ‘Languages’
  3. Locate your chosen language and tap to change the layout
  4. Choose your desired layout from the list
When you next open your keyboard, you’ll see that the layout has changed.
Cheers, hope it works.
