unlock xperia l
karnan
unlock xperia l
how to unlock xperia l??
pattern lock failed and data connection has been disabled.
how to do factory reset???
Uliwooly
you have 2 options keep trying to remember or use SUS to reset  your phone
11 REPLIES 11
Uliwooly
karnan
updation failed.!
quato_lenox
Turn off your phone and let it charge for about 25 minutes, to make sure it has enough power to complete the following process.
After charging your phone, make sure it's turned off. On your computer make sure you have internet access, and go to Sony PC Companion, and plug in your Xperia L. Make sure it doesn't turn itself back on. Now in PC Companion go to Update Phone --> Fix Phone. PC Companion will promt you that you will lose all your data, Tick the box confirming you understand, and follow the instructions. PC Companion will download the appropriate firmware (which sometimes takes 15 minutes or more). After it downloads it, you will be prompted to unplug your Xperia L from the PC. Unplug it, then take out the battery, wait about 10-15 seconds, put the battery and cover back on, WAIT to make sure your Xperia L does not turn itself back on, and if doesn't press and HOLD the volume-down button, and without letting go of it plug in your Xperia L to the PC. DO NOT LET GO OF THE VOLUME-DOWN BUTTON UNTIL PC COMPANION PROMPTS YOU TO!
There is another method to factory reset if you don't want to use Sony PC Companion, but it won't work if you turned off your phone at any time after forgetting your pattern (or facelock, or code, etc). If you have not turned off your phone, then take somebody else's phone, call your Xperia L, and answer the phone when it rings. Once you answer it, swipe down the screen with your finger, and enter Settings --> Backup And Reset --> Factory Data Reset. That's it.
karnan
Thank u....
done frm xperia care!
tonyjaimy
What is SUS
profile.country.RO.title
_alexdon_
Sony update service:
http://www.sonymobile.com/gb/tools/update-service/
Sony has dropped it unfortunately.
alexdon
PixieChic
Just checking, by losing data, will that include photos as well? I really don't want to lose my recent photos as my phone did not want to do a back up at all and from Friday my phone doesn't want to go past the sim lock.
_alexdon_
It will erase everything on internal memory.
alexdon
