26.1.B.2.102 Firmware for e2333
tmrpaixao
I'm curious to know if anyone knows if the firmware 26.1.B.2.102 will be released to the e2333 and if it has any advantages over the current one (26.1.B.1.85)?
profile.country.US.title
Qatrium
All available info can be found in this link:
http://www.xperiablog.net/2015/08/04/new-firmware-26-1-b-2-102-rolls-for-the-xperia-m4-aqua-dual/
Yet there's no official ETA for its release to E2333, you can contact Sony directly and see if they have more info:
http://support.sonymobile.com/global-en/contactUs/
EDIT: I see this on Sony servers this version has been already released to most E2333 variants (except for Nordic and Portugal customization), connect your phone to PC Companion and check for updates.
5 REPLIES 5
Qatrium
tmrpaixao
Thanks for the answer. I'm from Portugal, so that's why i asked since my phone is "up to date" (but still on 26.1.B.85) and i've seen in some forums that people with other variants of the M4 dual (e2323 and e2363) already have the updated firmware.
Qatrium
Then it should be a matter of time, keep checking periodically and hopefully it will be soon.
ivan5
And there will soon update for E2303 , because many phone lags. I m from Bulgaria.
EduRuiz
tmrpaixao: I've a M4 Aqua Dual E2333 just updated to the compilation you indicated. I'm from Spain but I get the mobile from Amazon (apparently imported from France).
I updated it because I got a message in my mobile indicating the update, but I do not get the information easily from Spanish SW Support as the E2333 is not selled in Spain and the model (M4 Aqua Dual) cannot be selected from the web. Only after I registered the mobile by IMEI, I get the update information (anyway, PC Companion did the location of the update without problem).
Anyway, I've to alert you: I've been 'fighting' with 'my Xperia' lock after the update. I got my mobile locked in the 'Protected' screen after the update and I was unable to unlock through my gmail accounts. I've been participating in other forum ("MXTP created problems for me.") about this problem but I cannot be sure if the problem was due to the update or it was by another reason (like having two gmail accounts in the mobile, as indicated as a possible reason by another participant on the forum).
At the end, I sent the mobile to Sony Support Service and they solved the problem by a SW update (but I don't have more details).
In my humble oppinion, do not have the 'my Xperia' protection activated when you were going to update the version, specially if you plan to update it through PC Companion (I don't know if update directly by WiFi activates the lock).
Good luck
