Hello,
I purchased an Xperia M dual phone recently in Hyderabad, India. At the store, I was told that there is an application which is provided at the Sony Service Center which will help us to move the apps to the sd card. Is it true? Is there such an app available? Request your quick action sooner than later.
Thank you!
No,there is not.You have to root to be able to move apps to SD:
http://www.xperiablog.net/2011/12/12/link2sd-guide-never-worry-about-internal-memory-limits-again/
what problem going on after root tell me plzzzzzzzz
bhargav
in service centre create root option on my xperia m dual
They will not root for you,rooting will void warranty.
This can't be done unless you root the phone > partition the SD card > install an apps2sd card app
