Bluetooth
Ehab01223710664
Bluetooth
I can't set the period time to be seen in Bluetooth , it's not active in my device , I have also Xperia m and this option is active and I can set the time easy
Tags (1)
Jake-SonyXperia
Champion
Hi Ehab01223710664,
The visible option has changed over the course of many android updates, I believe that Bluetooth is now visible while you are within the Bluetooth option in settings, once you move out of it then Bluetooth visibility turns off.
When you access Bluetooth do you see a message once you turn it on, better yet can you supply a screenshot when inside Bluetooth
2 REPLIES 2
profile.country.RO.title
_alexdon_
To be seen in bluetooth, just go to it's settings.
alexdon
Jake-SonyXperia
Champion
Hi Ehab01223710664,
