I have found a solution It looks like Sony decided to set M2 as low ram device. In build.prop file there is a line "ro.config.low_ram". It needs to be changed from true to false. You need to be rooted to do this. It fixes my problem and not showing OK Google hotword settings as well.
Not sure I'm getting the animation bug pard, but for Ok Google detection that's an option that you need to enable it manually:
Go to your App Drawer -> Google Settings -> Search & Now -> Voice -> "OK Google" detection
AOSP will have different options than stock Xperia software, do you have your "Google" app updated to latest version?
Of course I have. The latest one form the playstore. I've tried to clear cache, data, I have even installed old 3.5 Google App and then updating it, but it did nothing.
There is the problem we are facing: https://productforums.google.com/forum/#!topic/websearch/ROuqhFr2yvk
