- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi, I am from India. After the lollipop upadate, my Xperia m2 dual( 2302) camera shows some isues. Its image looks like artistic picture, lacks details. When zooming its feel too bad. Is any one have this issue?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
The camera seems to be fixed with latest update:
http://www.xperiablog.net/2015/12/29/new-xperia-m2-update-18-6-a-0-182-now-rolling/
For any questions related to update availability, please do not create other threads and remember that updates are released gradually, so timing and availability will differ:
/t5/Software-Updates/Android-5-1-When-are-we-getting-Lollipop-Which-Xperias-will-be/td-p/952233
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Can you please uplaod a sample photo to a drive or image hosting site and post the link here?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
This is another sample.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
This is odd, looks like there's a filter applied to it. We can start by clearing camera app cache:
- Go to Settings -> Apps -> All -> Camera -> Force stop, Clear data and restart your phone.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi @santhan
You can also try boot your device into safe mode and check if this issue persits. If everything works ok in this mode, a third party app is creating this problem. I´m at disposal for any question.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thank you for your suggestion. I tried the safe mode but the issue is still there.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi @santhan
Please, run a backup of the device information. Perform a system repair using PC Companion or Bridge for MAC. The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 80% battery. Switch off your phone and unplug from Pc (Hold volume up and power for around 10 seconds) Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the on screen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process. If you are using Windows 8/8.1 or a 64bit operating system then adjust the settings for PC Companion and run in compatibility mode and chose Windows 7 or XP. Keep us updated.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hello. i have exactly the same problem after update to lollipop (xperia m2 aqua d2403).
