Can't undo default app
PhilPetrol
I accidentally selected the Photos app as my default instead of Album which I normally use. I've been told that to undo a default app I should go to settings/apps/all to find the app and remove the default status. Trouble is that Photos is the one app that isn't in there.
Thommo
The app maybe called Photo editor or Photos and videos or as a last resort open Settings then Apps and tap the 3 dots menu option icon and tap on App preferences reset but this will also reset your ringtone etc
6 REPLIES 6
Thommo
Settings - Apps and swipe to All then locate and open the app Photos then tap on Clear cache and Clear data then reboot and test
profile.country.US.title
Qatrium
Are you sure you are on "All" tab? It should be there as long as it's installed. Try to find it also in "Downloaded" tab, after you find it scroll down and tap on "Clear defaults"
Thommo
PhilPetrol
Searched through downloads and all. Definitely not in either.
PhilPetrol
App reset preferences worked. Thanks for your help
Thommo
Glad it's sorted
