You should call them or use livechat. Also, they will have to look at the device to check the extent of the damage.
@Daruma69 did you called them or email them? if you email them they probably have been on their days off since its the weekend, what if you call them?
Are you referring to the SIM card flap/cover?
http://support.sonymobile.com/global-en/xperiam2/userguide/Assembly/
