DDMM
Clock problem
Hello everyone,
I have a problem with right-top corner clock.
System time is true but this clock shows wrong.
Current time is 21:53 clock shows 11:51 right now.
Regards.
Tags (3)
4 REPLIES 4
profile.country.PH.title
MarlonUk1
is it the same when you are on safe mode?
try to perform a software repair using Xperia COmpanion
Nervous
I had the same problem. Also my alarm clock hadn't work properly. It disappeared one day (probably after software update).
Mr-samar
The same problem was in my phone but when turnedoff Automatic date & time and Automatic time zone,this is now removed.You may try it.
Goobie
I have the same problem, it started happening after Android 6 upgrade. I tried all the advice above, but still the clock will not keep time. Very frustrating
