How to delete group icons
Dpw
I can't delete the groups shortcuts stuck in mobile's home screen
Dpw
I worked out how to delete group shortcuts on homepage with help from someone in the support forum. Press on shortcut app until delete appears at the top of screen and then drag app up to and over delete.
5 REPLIES 5
profile.country.PH.title
MarlonUk1
Did you try long press on the icon and drag upwards
Dpw
No but I'll try it thanks.
Jake-SonyXperia
Champion
Hi @Sf5,
Sorry to hear this, if the instructions supplied by @nolramlb don't work, you can always clear the Home screen data, however, this will remove all shortcuts and set the default.
Although I do believe the instructions by @nolramlb will work fine.
Apps > Settings > Apps > Home Screen/ Xperia Home Screen > Storage > Clear Data
Let us know how you get on regardless.
Dpw
Jake-SonyXperia
Champion
Glad to hear it, let us know if you have anymore questions Slightly_smiling_Face
