I can not answer the calls
Marwa95
I have a problem with calling answer when someone calling me a small window appear with answer and decline when i click on answer or decline the phone does not answer or decline
What can i do ?
Uliwooly
@Marwa95
Check if you experience the same in safe mode
7 REPLIES 7
Uliwooly
@Marwa95
Marwa95
Ok now l have active the safe mode ,but i can not find or open any application which i had installed
Marwa95
But the problem had solved
Uliwooly
@Marwa95
So it works fine on safe mode? if it does then it's a third party causing this problem.
Marwa95
Yes now the calling work but no applications Grinning_Face what should i do ?
Close the safe mode ?
Marwa95
Oknow no problems thanks a lot
Uliwooly
@Marwa95
restart the phone > it will boot on normal mode, if you encounter the same issue, you will have to start uninstalling apps until you find the culprit
