lagging issue sony m4 aqua dual
farhan21
i just updated my sony m4 aqua dual sim,before the update everything was fine but after the update i keep having lagging issue when playing games / texting and the battery dry out faster than before plus i check my memory and i still have 1 GB of memory free on the RAM ,plis have an update that will fix these problem especially the lagging coz its has a 2GB ram
Samuel1
Hero
In that case I suggest that you try to repair the phone software using PC Companion..
Before repairing your device you may want to backup your information first. Check out this topic for more information on how to.
How to backup?
If the issue should still remain I think that this needs to be examined and fixed at a repair center. For more information about how to submit your phone for repair and where, contact your local support team.
16 REPLIES 16
Samuel1
Hero
Did you reset the phone after you updated it? If not, you should give it a try. Let us know the results.
farhan21
i format it 3 times after the update but still face the same issue
Samuel1
Hero
How to backup?
anix69
Same issue here......after the update the phone(m4) the games are lagging tried the repair option but still facing the issue
chayanray
@ samuel
The problem is with the new update, in order to control the heat, the processors core remain un utilized, can you please convey the message to technical team, pls fix this lagging behaviour of the phone, give us an oprion to opt between high performance mode and heat control mode, so that it remains user dependant, so that while playing games we can switch over to high performance mode
Pls, convey to technical team, it is very irritating to have such lags while playing low end games in a 24 k phone
Regards
A dissappointed Sony xperia fan
anix69
Yes a temporary option to switch modes would do until the technical team comes up with a permanent solution......
chayanray
@ samuel
Pls, reply. Has the issue been communicated to xperia technical team
freakk
Hi Guys,
Which version of the ROM is causing the lag? Just want to know so i don't update the phone anymore.
Thanks.
chayanray
26.1.B.2.102 for the dual sim version model no E2363
