Hello
When i start an application, and after i stop it, i can read the historic in "browsed application" (the third screen).
I want to know if it's possible to parameter the phone to get this list invisible in this screen.
Thanks
This is a feature in all Android phones, opened apps/webpages will remain in this list untill you clear it. You can swipe any application from the list to remove it, but it will appear again if you open it again. Or you can you "Clear all" button to remove all the apps in the list.
Yes thanks
that is what i did.
But i don't want to see this list appear on the third screen. Is it possible to stop the création of this list (in parameters)?
