I have attempted to put a codes to unlock network but none of them work and and i didnt know that theres attempt numbers to enter a code and now i have 0 attempts what should i do now can i reset it ? plss help
Hi @Mic1502, welcome to our forum!
You have five tries to enter the correct code to unlock the network lock on your device and if you run out of attempts, I would recommend that you get in touch with your Local support team and they will assist you further with this!
I hope that helps!
