M5 constantly vibrating when plugged into power supply via USB cable
Eden0032
Just purchased an M5 today, and when I plug it into the power supply via USB to charge it, it constantly vibrates because the charging stops and starts.
When I plug into the PC via USB it charges fine.
I'm currently preparing for and running the PC Companion to try to fix the issue, but in the meantime, does anybody have any suggestions as to what the cause of this issue may be and how to fix it?
Thanks!
Uliwooly
@Eden0032
do you experience the same with other wall chargers and different wall sockets?
9 REPLIES 9
Uliwooly
@Eden0032
Eden0032
@uliwooly wrote:
@Eden0032
Thanks - I've managed to scavenge around and have found another wall plug for the USB cable...will test for the next 30 or so minutes and reply back.
Eden0032
@Eden0032 wrote:
@uliwooly wrote:
@Eden0032
Seems to be working okay at the moment - perhaps it was a faulty wall plug (which I've been using for 3 years without any fault at all, including earlier today for my previous phone!).
Of course, if it still plays up I will reply here.
Uliwooly
@Eden0032
Keep us updated
Christofer
Champion
Hi @Eden0032,
It does seem like the charger itself is the cause of this. Were you using the one that came with the phone or was this another charger?
Eden0032
The phone only came with the USB cable so I had to use the plug that I've been using fine for my previous phone.
I've had it on charge over night via portable phone charger with no issues so all seems good.
It does look like my plug has become faulty at a really coincidental time.
Thanks for the help!
Christofer
Champion
I'm glad to hear that you were able to identify the cause. Slightly_smiling_Face
ykphuah
@Eden0032 wrote:
@Eden0032 wrote:
@uliwooly wrote:
@Eden0032
Maybe you didn't notice last time because your previous phone doesn't vibrate when you start/stop charging?
Sony I think it vibrates when connecting and disconnecting, so if the charger kept on on/off/on/off, your other devices might not show this properly.
Uliwooly
@ykphuah
That's correct, Xperias will vibrate when connected
