No setting to change USB connection mode
Koningdefuijk
I've just bought a m4.
Now I wanted to change the USB connection met.
But it's not there.
The only thing I can do is to install the software for pc but that's it.
Anyone else has this problem?
Or does anyone know how to solve this.
The phone is up to date with android and the build version.
Christofer
Champion
Hi @Koningdefuijk,
Are you referring to changing the USB connection mode to MSC? If so this feature is not available in the Xperia M4 Aqua. MTP is the only available USB connection mode so there is no setting to change this.
2 REPLIES 2
Christofer
Champion
Hi @Koningdefuijk,
Koningdefuijk
Yes that's it.
And thanks for the fast reply.
Must say that's really bad. Hope they fix this in the next update.
