Problem in incoming calls
XperiaM4
My Xperia M4 Dual ringtone doesnt ring incoming calls. Speaker works fine when I listen music. And sim 1 keeps rejecting calls.
If there is anything Sony can do, please resolve.
18 REPLIES 18
anestemin
Is it possible to keep screen off and prevent randomly predefined text message sending
At least keep screen off during incoming call when headset plugged in or SBH50 headset paired.
I love bike ridinig. My xperia goes with me every time. but i couldnt answer single incoming call yet. Phone ends call or sends predefined sms. Every time when i have call i have to stop my bike get off carefully take phone out of my pocket and answer it. its so annoying
P.S. English is not my native language i hope i could post what i mean.
Appreciate your help
AlfredPuth
Good day,
I experience that after an incoming call was received and answered the Ring volume is set to low.
I try to make sure that I don't touch the volume controle key. I thought that I might touch the down key for the volume.
It seems as if it just happens when a call was received and not on making a call.
Any suggestion on what this might be or how to resolve.
It is a iritating to everytime after a call check the Ring Volume and having to increase it back to my prefered level.
Thanks,
Alfred
Tags (1)
Thommo
Try an app preferences reset - Settings then Apps then tap the 3 dots then Reset app preferences then reboot and test, Take note that ringtones etc will revert back to default
AlfredPuth
I have applied the rest of app preferences yesterday. I received an incoming call and the volume did not go lower. I left it until today to test. Just received a incoming call, the ring volume is low again after the call was ended. Anything else that I can do? Thanks.
Kgilly46
I had same problem went into ee shop, u need to check haven't got it on priority or silent setting. Press volume button at side of phone check it's on sound setting which u can see under line at top of drop down menu when sound button pressed. I had mine on priority.
PraveshIssen
Smartphone sony xperia z5 dual ....waiting for your reply
Pa3k
I have a problem with Sony M4 Aqua, Incoming calls ring twice from the caller before ringing on my device. There is +-3sec delay
aruntriplee
Hi sir..I am using Sony m4 aqua...I am going to sound and notification settings means it come back to home screen.. How to solve the problem.. Pls tel me the solution
Georgi1
Re: Problem in incoming calls
How can i disable predefinited mesages on incoming calls?în my pocket reject call and sent predefinited mesage before i pull it to answer. It is a stupid option and i don't need it. And many times i lose some important calls because i can't hear when ring.after a second reject call and sent a stupid predefinited mesage.I hate you sony for that!
I have the same problem. I don't need this function and I want to disable it, how can do that?
