I have got some problems with Xperia m4 dual aqua,Can you show me how to do remove or disable the the ' rejected called with message '
Hi @Vdhieudqs,
Are you referring to the option where you can swipe upwards to choose a message to reject an incoming call with? To my knowledge, there is no way to deactivate this feature.
Hi, I have the same problem as you. Have you already resolve that issue? Thank you.
Hi @aandrea, do you also refer to the swiping feature which you would like to disable? I'm afraid that my reply is as I posted a bit earlier that there is no way to my knowledge to disable this.
Hi @valyo_bg, thanks for the suggestion! It is true that this may be resolved by switching Dialers, but as far as using the pre installed Dialer I am afraid that there is currently not a way to disable this - however I'll make sure to forward feedback regarding this internally!
