Sony charger substituts
Nexusrox
My charger is lost and was using a samsung charger. Recently it got very slow. So i need a good substitute as Sony chargers cant be found here. Thanks in advance
10 REPLIES 10
Jonas
Master
Hi @Nexusrox,
I'm sorry to hear about that. Slightly_frowning_Face
If you are located in a country where our eStore is open, I would recommend having a look there and see if you can order a new charger from there.
https://www.sonymobile.com/global-en/shop/
Click on the country you are located in > click on "Chargers & docks" at the top of the page.
The name of the charger that was included with your phone is named "EP800".
If the eStore is not available in your country, I'd recommend getting in contact with your Local support team since they are the experts on your market and hopefully they can help you with getting a hold of a new charger or point you to a retailer.
Let me know how it goes! Slightly_smiling_Face
Shen02
How fast is EP800 charger..??
Can I use Z3+, Z5 or X charger..??
NeoBeum
Enthusiast
2.1A
Jonas
Master
Hi @Shen02,
Below you will find the information regarding the EP800 charger!
Output 5.0VDC = 850mA (VDC=Volts Direct Current, mA=milliamps).
You will be able to charge an M4 Aqua with a charger that was included with Z3+ (EP880), Z5 or Xperia X (UCH20).
I hope that answers your question, if not let me know! Slightly_smiling_Face
Shen02
@Jonas
Thanks for your information..
If I use Z3+, Z5 or X charger for my M4 Aqua, there's no
effect for my M4 Aqua battery will damage..??
Coz M4 Aqua charger EP800 is slow and take
2hours 40minutes to fully charge.
That's reason why I want to change M4 Aqua EP800 charger to Z3+, Z5 or X charger.
Jonas
Master
Hi again!
Using a UCH20 or EP880/EP881 will not damage your device in any way, do note that Xperia M4 Aqua isn't listed as one of the compatible devices for these chargers so may not experience that the device will charge faster, it might even charge slower.
I would say that 2 hours and 40 minutes is an excellent time for a full charge from 0% too 100%, the information listed in the environmental declaration is 3 hours and 50 minutes.
http://www-support-downloads.sonymobile.com/e2303/environmental_E2303_E2306_E2312_E2333_E2353_E2363_...
Let me know how it worked out for you! Slightly_smiling_Face
Shen02
@Jonas
I already try charging M4 Aqua with EP880 (Z3+ charger) and its take 1hour 40minutes to fully.
According with your information about UCH20 charger this device Xperia M4 Aqua not compatible with it even it's support Qualcomm quick charge 2.0.
I think M4 Aqua will fast charging with UCH10.
Jonas
Master
Thanks for the swift reply!
So it's 1 hour faster with the other charger, that's great to hear! Slightly_smiling_Face
The Xperia M4 Aqua has no support for quick charge, not 2.0 or 3.0, so charging your phone with UCH10 will not result in the phone using Quick charge.
For quick charge to work the phone has to support either Quick charge 2.0, 3.0 or MediaTek Pump Express 2.0 Plus and be charged with a quick charger, UCH10, UCH12 or UCH12W.
I hope that answers your question and have a great weekend! Slightly_smiling_Face
Shen02
I will stay using EP880 charger coz its compatible with Xperia M4 Aqua..
Thanks for answering my questions Sony Xperia Support Team ☺
I will looking forward for Sony Xperia
Sony
Make it. Believe it.
