The speaker will work normally after it will dry up completely.This might take several days.
I encountered the same with Z1 and Z2, you can play music safely.
It depends, it will heat up while playing games or when browsing on mobile data.
Do you have battery saving apps, any task killer? Also, do you use facebook a lot?
